Author Topic: Unable to change soldermask color in 3D mode?  (Read 2942 times)
Offline Pack34Topic starter
« on: March 14, 2018, 08:45:45 pm »
I think I've run into an odd mode. I can't change the soldermask color while in 3D mode. I also can't change between 2D and 3D mode using the dropdown on the primary toolbar. I have to go to View > 3D mode to switch.
Has anyone run into this?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Unable to change soldermask color in 3D mode?
« Reply #1 on: March 14, 2018, 09:51:18 pm »
Did you accidentally delete the view mode on the layer dialog?
Seven Transistor Labs, LLC
Offline mars01
« Reply #2 on: March 17, 2018, 09:25:08 am »
Check if you still have the *.config_3D files in the following folder:
C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {Your_GUID_here}\ViewConfigurations
In the same folder check the configuration file named:
RegisteredViewConfigurations.ini
if you still have all the "views" registered.
The content should be like this:
[general]
LastCustomFolder=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\
[config_2dsimple]
Altium Standard 2D=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium Standard 2D.config_2dsimple
Altium Transparent 2D=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium Transparent 2D.config_2dsimple
[config_3d]
Altium 3D Black=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Black.config_3d
Altium 3D Blue=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Blue.config_3d
Altium 3D Brown=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Brown.config_3d
Altium 3D Color By Layer=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Color By Layer.config_3d
Altium 3D Dk Green=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Dk Green.config_3d
Altium 3D Lt Green=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Lt Green.config_3d
Altium 3D Red=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D Red.config_3d
Altium 3D White=C:\Users\Your_username_here\AppData\Roaming\Altium\Altium Designer {YOUR_GUID_HERE}\ViewConfigurations\Altium 3D White.config_3d
