Author Topic: Track width error [SOLVED]  (Read 1425 times)
Offline Lucky-LukaTopic starter
« on: February 16, 2021, 03:40:05 pm »
Hi all
I've placed all the components in the PCB. I've run the DESIGN RULE CHECK.
I've got width constraint error... I cannot understand it since I've got still no tracks in the PCB...
The error is referred to the first pin of the headers...
I attach the error, the image of the footprint of one of the headers with the error and the error shown as "< 0.3mm" (the min track width rule I've chosen) in the PCB after the error check.
Can anyone help me?
Thanks
« Last Edit: February 16, 2021, 05:58:03 pm by Lucky-Luka »
Memento audere semper.
Offline penfold
Re: Track width error
« Reply #1 on: February 16, 2021, 03:43:23 pm »
Can you check the footprint? Is there some fragment of a trace on the top layer? What's the bulge on the left hand side of pad 1?
The following users thanked this post: Lucky-Luka
« Reply #2 on: February 16, 2021, 03:57:43 pm »
I've disassembled the footprint and I've found a track under every first pin of the headers!
I haven't drawn them consciously...
Mistery
Now that I've deleted them all those errors are gone.
Offline penfold
« Reply #3 on: February 16, 2021, 04:02:50 pm »
Great! Its easily done, just for future note, if you use single-layer mode and scroll through the layers it makes things like that stand out a bit easier for problem finding
