Author Topic: Polygon not pouring properly  (Read 13700 times)
Offline grimmjawTopic starter
« on: October 02, 2015, 02:32:32 am »
hi guys,
i have a problem that, my polygon is not pouring the same netz/object .
Not really sure what happened, the polygon is set to pour over all same net objects and set connect to anode.
I have repour the polygon many time but failed to get any connection.
Has anyone have any idea  :-//
Offline David_AVD
Re: Polygon not pouring properly
« Reply #1 on: October 02, 2015, 06:54:07 am »
Perhaps there a DRC rule (poly connect) that is causing issues?
« Reply #2 on: October 02, 2015, 07:00:28 am »
not sure..but the rule looks okay to me,no?  :-//
« Reply #3 on: October 02, 2015, 07:04:19 am »
Off topic, but why you have positive solder mask expansion on vias? Is it supposed to be no expansion or negative expansion?
« Reply #4 on: October 02, 2015, 07:24:45 am »
The purple ring on vias. The purple area won't be covered with solder mask.
I understand what you meant by the solder mask expansion. The area should not be covered by solder mask.
But no sure what you asking tho(in the original post)..it is positive expansion  :-//
« Reply #5 on: October 02, 2015, 07:29:46 am »
Try direct connection, instead of the relief one. If still not work, pls post a screenshot of clearance tab.
Direct connection worked but i prefer thermal relief connection. With direct connection it will be hard to solder/desolder .
See attachement for the clearnce .look okay to me
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 02, 2015, 07:38:38 am »
It seems like you have a rule which is preventing it from connecting, indeed causing very slightly more clearance than to different nets.
Seven Transistor Labs, LLC
« Reply #7 on: October 02, 2015, 07:46:01 am »
@blueskull , the board is quite big with 4 layer( copper floading), and even with high-end soldering iron it will be an issue,btw I using ERSA ICON2 and a Metcal.
Anyway thanks for you time
PS:Still not getting the expansion issue. perhaps i having a brain fart today. I want it to expose copper
« Reply #8 on: October 02, 2015, 07:47:58 am »
@Tim...I suspect as much, but i have failed to locate which rule. Is there any way to restore to default rules in altium?
Online T3sl4co1l
« Reply #9 on: October 02, 2015, 08:07:07 am »
Can you send your .PcbDoc?
Offline free_electron
    • SiliconValleyGarage
« Reply #10 on: October 02, 2015, 03:28:32 pm »
rule editor
-> PLane-> Polgon connect style ->
decrease the air gap in your polygon.
set to 45 degree angle
 most likely that connector is so dense the spokes cannot be pulled.
Offline Bud
« Reply #11 on: October 03, 2015, 02:03:12 am »
@grimmjaw
blueskull is talking about the 4 small vias in the top part of the screenshot, not about the connector thruhole pads.
Do you really need those vias exposed and not covered by solder mask ?
« Reply #12 on: October 05, 2015, 04:02:54 am »
rule editor
Nope..still no connection  |O |O
Online T3sl4co1l
« Reply #13 on: October 05, 2015, 11:28:24 am »
Can you share the PcbDoc?
Offline David_AVD
« Reply #14 on: October 05, 2015, 08:54:26 pm »
Even a copy with most parts removed (that still has the issue) would do.
« Reply #15 on: October 06, 2015, 12:58:52 am »
so an update..I gave up on the polygon and move on with the routing.
And to my surprise the after a few hours of routing, the polygon now pour/connect correctly. :-+
I have not change the rules..so i have no idea why it worked now  :-//
