Well guys, looks like the method with Inkscape is working best. When you get into it, it's very simple. Thank you guys for your support!
Update: Doh! Altium Designer has an option to print a negative artwork! It's all about playing with the print colors. Found this on the net and it works ->
Draw your design
Select a different layer, say Layer 1.
Place a 'Fill' on this layer covering all of the design.
Goto print setup.
Choose 'colour' for the artwork, not monochrome.
Choose 'White' for the colour of the tracks and any other details.
Choose 'Black' for the fill layer.
Print.
The artwork will come out negative.
* M4trix ashamed...
