Do you have any components on the bottom layer and the bottom layer is turned off? Try turning on the bottom layer.
Did you already try 'Clear error markers'Maybe Hide all nets then Show all nets, under view menu.If it still persists may be necessary to copy the information to a new PCB file or similar.
