Author Topic: Strange Altium 3D problem, no soldermask !  (Read 11212 times)
Offline kilohercasTopic starter
  • Engineer
« on: March 24, 2017, 07:58:24 pm »
Hello, i guess i pressed something or Altium is just buggy, but for some reason i can't get solder mask to show up. I clearly have it in layers, but just can't see it.
Did try to press Shift+S, but that does not help, also opacity settings are correct in Layer manager.
Any idea what i did, and how to fix this ? It is not a big problem, but still, want to see complete board :) ( It is same on 17, and 16 versions, all legal)
Offline voltsandjolts
Re: Strange Altium 3D problem, no soldermask !
« Reply #1 on: March 24, 2017, 08:31:17 pm »
Layer Set?
Design > Manage Layer Sets > Boards Layer Sets
  • Engineer
« Reply #2 on: March 24, 2017, 09:08:31 pm »
Looks normal, all layers are enabled.  ???
« Reply #3 on: March 24, 2017, 09:37:11 pm »
Layer Stack? Has the Top/Bottom Solder layer been deleted / thickness?
Design > Layer Stack Manager
Offline corax
« Reply #4 on: March 24, 2017, 09:52:20 pm »
Solder mask opacity setting?
Right click on board -> Options -> Board Layers and Colors -> solder mask check-boxes and opacity sliders in 'Colors and Visibility' section
  • Engineer
« Reply #5 on: March 25, 2017, 06:54:11 am »
No, they are 100% as i stated in my first post picture. Changing scenes did not help also.
No, it is enabled, and  0.0106mm thick (default value)
I did all of those in the first place, but it is something else...
Offline corax
« Reply #6 on: March 25, 2017, 08:48:50 am »
Ah, sorry, I missed your second image in your post.
What about solder mask expansion rules?  A large enough expansion could result in no mask on the board.
What does the mask layer look like in 2D mode?
  • Engineer
« Reply #7 on: March 25, 2017, 12:30:32 pm »
Hm, you are right, somehow i have no top and bottom solder mask, only on TH pins, but how could i done this ?
But I have Top and Bottom Paste. So how the hell i could disable top and bottom solde rmask on every pad and every track ?  :-//
Basically i have a layer, but it is nearly empty, only multilayer show up on this layer  |O
  • Engineer
« Reply #8 on: March 25, 2017, 01:11:58 pm »
I have it on gerbers, but i don't see it in altium, or in 3D, somehing is horibly wrong here.
and if i select top solder layer, and make square, it does not show up :D  :-DD So i think it is something to do with Altium itself
Offline julianhigginson
« Reply #9 on: March 27, 2017, 12:42:17 am »
how does it show in other projects?
  • Engineer
« Reply #10 on: March 27, 2017, 05:47:02 pm »
Found a problem !  |O
When i was defying board outline, i simply selected pcb outline that i made in keep out layer, but in the middle of pcb i found tiny zero size and length dot in keep out layer.
It messed up all of this, because Altium was thinking that was my board :D:D
After deleting and redefining board, it started working again.
