Author Topic: Can reference location for pads be changed from center to corner?  (Read 2073 times)
Offline BMFTopic starter
Is there an Altium feature or technique that allows pads to be referenced in location by their corner instead of their center?  Most mechanical drawings use corner references for pad locations so being able to use that data directly would be convenient and less error prone. I most often like to drop pads of correct size near their correct location and then use XY coordinated to get them into position. Of course for evenly spaced pads I just array them.
Offline julianhigginson
Re: Can reference location for pads be changed from center to corner?
« Reply #1 on: March 27, 2017, 12:45:39 am »
No way that I know of.
You get used to recalculating pad centre positions from drawings in your head after a while....
Offline logictom
« Reply #2 on: March 27, 2017, 07:47:58 am »
You could modify the PCB library footprint and set the reference point in the corner but this would require doing this for every component, otherwise I don't know of any way to do this.
Offline Mattylad
« Reply #3 on: March 28, 2017, 08:25:25 pm »
The drawings that show pads dimensioned like that are because they are done by someone that does not know how to dimension footprints, usually a mechanical draftsman.  :)
Matty
CID+
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: March 28, 2017, 09:30:56 pm »
Yes.
But you don't want to.
The pad center is used for trace connections, so you'd have all the traces connecting to one corner.  How bizarre.
Seven Transistor Labs, LLC
