Author Topic: Named polygon direct connection and another clearance  (Read 1837 times)
Offline Kanc1erzTopic starter
  • Being a noob the whole life :)
« on: January 17, 2019, 11:02:05 am »
is there fast possibility to make a named polygon using direct connection and another clearance? For instance:
I got converter MP3414 nad instead of routing it normally it would be better to make those connections (with inductor, caps and so on) using a polygon.
Now I am doing it by writing rule like: InComponent('U7') or InComponent('L1') etc. but it would be more convenient if I could write: InNamedPolygon('MP3414_Inductor'). It obviously doesn't work, as in the screen below.
Maybe you have some other "pro tips" for noobs like me? :)
Re: Named polygon direct connection and another clearance
« Reply #1 on: January 17, 2019, 01:46:43 pm »
The answer is: IsNamedPolygon('PolyName')  :-[  |O
« Last Edit: January 17, 2019, 02:22:16 pm by Kanc1erz »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: January 17, 2019, 09:33:18 pm »
Polygons are weird... sometimes you use InPoly, sometimes you use IsNamedPolygon, sometimes you... ::)
Seven Transistor Labs, LLC
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: January 21, 2019, 03:11:17 am »
In access the objects that make up the polygon ( a polygon is a tlist of vectors)
Is means the object itself.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #4 on: January 22, 2019, 04:41:49 pm »
Another strange thing is that copper polygons are not considered electrical by the "IsElectrical" query. That one had me scratching heads for quite awhile.
A guy just wanted to write a board outline rule for copper and my polygons were not following the rule. If it wasn't for the whole test query feature I would have gone insane long ago.
“They Don’t Think It Be Like It Is, But It Do”
