Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Routing a component on one side of board only
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Routing a component on one side of board only (Read 1729 times)
brownt
Regular Contributor
Country:
on:
June 23, 2017, 09:06:03 pm »
Hi, I am trying to route a component on one side of the board only. I have changed the pads from 'simple' to 'Top-Middle-Bottom' and put in a size for the bottom only. But when the board is routed, it still routes on both sides. why would that be?
Logged
Fire Doger
Regular Contributor
Country:
Stefanos
Re: Routing a component on one side of board only
Reply #1 on:
June 25, 2017, 05:35:55 pm »
Routing in 1 layer is very difficult on auto-router because component placement makes all the difference. The only reason to use it is for an early image of how final result will look like (if you are inexperienced) and make a ton of adjustments for the best result.
If you have AD17 you can use active route on some tracks which in my opinion is very nice for simple routing.
If you have a very complicated board consider using 2 layers. Why you want 1 side? Because you will produce thousands of them or you will make it yourself?
With photosensitive pcb its possible to make double sided. I did it with the first try.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
