Author Topic: AD 18/19 issue with clearance between polygon and rest of the components  (Read 1202 times)
Offline Kanc1erzTopic starter
  • Being a noob the whole life :)
Hello,
I have really severe issue with clearance between polygon (in my case GND) and rest of the components such as vias, pads and so on. I mean the clearance is equal to zero (but GND pads have normal defined reliefs) as in the screenshots below. I read all the rules (not many of them) I even deleted ones regarding clearance/polygons and still nothing helps.
Is someone more advanced can tell what is wrong I would be very grateful.
I would add that I tried it on two separate computers and on two different versions of AD (I use 18.1.9) but tried on 19.0.14 - same problem.
Offline toybuilder
Re: AD 18/19 issue with clearance between polygon and rest of the components
« Reply #1 on: November 05, 2019, 10:23:57 am »
You're missing a 'catch all' rule for clearance. You defined three clearance rule scopes, but anything that do not meet those scopes will not have any clearance rule appy to them -- thus the zero clearance.
Set up a rule for an "all-all" scope as your lowest priority and set your clearance there.
The following users thanked this post: Kanc1erz
« Reply #2 on: November 05, 2019, 10:46:39 am »
Well, time to buy glasses... Thank you!
I have one more problem then..
It is somehow connected to the battery pad with slot-hole offset, maybe you can also find some solution, as I can't..
I am sure that the problem is caused by this pad, because when I move the component out of pcb, then the plane is poured completely fine.
Please, look at it.
And when I change poly type from solid to hatched more magic appears (second screen).
Offline thm_w
  • Non-expert
« Reply #3 on: November 05, 2019, 09:18:17 pm »
Hole size 10mm and length 1mm, you have some things backwards no?
