It may not be exactly the problem you have but I find the following the best arrangement.
- Place the board outline on the keep out layer.
This will mean that the copper pour will be set back from the edge of the board - which is a good idea in any case.
- Make sure you have 'remove isolated copper' (from memory) on the copper pour.
bye
