Hello, I have a big polygon connected to "net A" and I want to create another polygon inside the first one connected to "net B".
Both polygons are on the same layer so when I do the second polygon it's overlapped to the first. How can I separate the 2 polygon between them without redo the first?
I hope that the question is clear,
thanks
