Author Topic: Output Jobs missing files  (Read 473 times)
Offline MMussioTopic starter
  • Country: br
« on: February 25, 2026, 05:04:59 pm »
Hello,
I'm currently using Altium Designer v26.3.0 and i use 2 different output jobs: fabrication and assembly. I'm using 365 Altium for my full release download, and not manually generating any of the files.
  • Fabrication: Gerber and NC Drill Files, Validation files (DRC, ERC and DiffReport), Draftsman Assembly (PDF) File and STEP File
  • Assembly:BOM, P&P and Schematics (PDF)
Currently I'm having a problem generating the two PDF Files. I always get only one in the release, which is weird to me. They aren't the same file and are not even in the same output container. I had the same problem trying to generate 2 different P&P files (one only SMD and another one only PTH). It's like one overwrites the previous. I've tried changing the path the PDFs are generated, without success. Has anybody faced the same issues?
Regards
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Output Jobs missing files
« Reply #1 on: February 25, 2026, 05:20:10 pm »
If you want two PDFs you have to ask for two PDFs you are only giving it one document.
2770481-0
If you are using managed releases you need to make sure the outjob is enabled for the type of output.
2770477-1
« Last Edit: February 25, 2026, 05:27:34 pm by Pseudobyte »
“They Don’t Think It Be Like It Is, But It Do”
