Author Topic: how to enable all layers in Altium  (Read 7714 times)
Offline ali_asadzadehTopic starter
« on: May 30, 2017, 08:27:14 am »
Hi
I have get  design files from TI and when I open the files in altium every single layer is only active, the TIDA-00707 design from TI, how could I enable all layers at once, it's on my never!
Here is a picture for your reference.
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline electricar
Re: how to enable all layers in Altium
« Reply #1 on: May 30, 2017, 08:28:11 am »
Shift+s
The following users thanked this post: Mechatrommer
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: May 30, 2017, 02:07:53 pm »
Shift+s
great! but i tried to find in where menu this shortcut exist, none found. so i have to ask, where i can find such mystical shortcuts help guide?
The following users thanked this post: ali_asadzadeh
Offline voltsandjolts
« Reply #3 on: May 30, 2017, 02:23:50 pm »
View > Workspace Panels > Help > Shortcuts
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: May 30, 2017, 04:32:32 pm »
Also, hit the "LS" in the lower left corner (layer sets), All Layers.
If you've saved a view configuration (on the Layers dialog, L) with some layers disabled (most often, copper and mechanical layers you weren't using at the time you saved it), you want to click All Layers to make everything visible again.
Seven Transistor Labs, LLC
« Reply #5 on: May 31, 2017, 05:21:40 am »
Shift+s
