Hi!
I'm having a slight hiccup with my thinking in a PCB project here. I've created a schematic symbol and footprint for an Atmel SAM4L MCU, spanning several sub-parts so I could put them on different pages. However, I get a warning when compiling the project, saying that I have
[Warning] IC Power.SchDoc Compiler Duplicate pins in component Pin U1-4 and Pin U1-4
as well as some errors for duplicate net names where I have open pins.
This is kind of annoying, since I've for example put the Reset pin available on both the Power-subpart as well as the JTAG-subpart, as I feel it's logical to place all connections that are logically grouped together, together. Is this bad form, or is there a nice way of doing this?
I could probably have the pin available in only one place, and then put a port there and in the JTAG sheet, but... when I already have a part where all the other JTAG related connections are grouped, I'd be sort of miffed if I have to remove / redo the ones that are used more than one place (See picture 1 & 2). Another example is the HL6528-chip I'm using; Some pins that can be GPIO in one configuration and specific,
different pins in another should be possible to group together in my head. Is this totally crazy from my side?
Same goes for ICSP-connectors and other stuff (not for this project though). So the generalized question is:
Do pins that are needed in different parts of a circuit, have to be located only one place in a schematic component?
