Author Topic: Single BOM for multiple projects  (Read 3128 times)
Offline slashguitarTopic starter
« on: November 25, 2014, 10:09:59 pm »
I am working on a project consisting of multiple boards. Is there a way to generate a single BOM for multiple projects or do I have to go through them manually?
Thanks
Offline Gelf54
Re: Single BOM for multiple projects
« Reply #1 on: February 09, 2015, 05:16:20 am »
The only way I know atm is to create a new composite project with a master sheet containing sheet symbols for all your other schematics. You can then generate a BOM from this, but if you have multiple copies of a particular schematic sheet on your master, it only includes the parts from one of these sheets for the BOM, which seems like a bug to me. I'm currently searching for a solution to this.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: February 09, 2015, 07:00:40 am »
Try using hierarchical sheet symbols?  Then you can instantiate repeated sheets.
Have fun with the net errors on that project; you can probably (and probably should..) turn off basically everything (errors, netlist compile, PCB transfer..) in such a project so it does exactly what it's supposed to do and nothing else.
Not something I've done / had to do, but a neat idea.  One rub: if you have assembly variants in the main project, those are project-specific settings and won't follow the sheets (of course).
Seven Transistor Labs, LLC
