Author Topic: How to import a bitmap logo into a PCB library?  (Read 7224 times)
Offline 8086Topic starter
    • Circuitology - Electronics Assembly
« on: November 01, 2012, 04:49:26 pm »
I use Altium Designer for work, but the rest of the company uses Protel 99SE.
I've made a library component with a logo that works with AD, but when I save in Protel format, it appears blank. I assume this is because the logo is made of 'regions' - which I suspect Protel doesn't understand?
I have been looking for a way to convert regions to polygons or similar but to no avail - does anyone have any idea how I might get the logo to show in Protel?
Cheers.
Offline sacherjj
Re: How to import a bitmap logo into a PCB library?
« Reply #1 on: November 01, 2012, 06:10:47 pm »
There was a program floating around somewhere called PCBLogo.  I remember using it to get a logo into an old EDA tool.  Not sure if that helps any.  It was shareware for $10-15 I think.  Not sure if it is still around.
Not familiar with Protel at all.  I do know that some apps are picky about bit depth on bitmaps.  Most would want 1 bit Bitmap.  (i.e. Black and White only).  So make sure it is formatted like that in a paint program.
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: November 02, 2012, 02:20:54 am »
there is a script in altium designer that will read a black and white bitma[ and convert it into line art.
look in the install directory under examples in pascalscripts.
« Reply #3 on: November 19, 2012, 05:20:03 pm »
Thanks guys, I found the script but it didn't come out too well. In the end I just used Altium and didn't bother with Protel.
