Author Topic: Push routing not working in Altium  (Read 5109 times)
Offline ECEdesignTopic starter
« on: November 21, 2016, 02:14:17 am »
I'm pretty frustrated, I've gone through the settings in Altium so many times and still can't get push routing (or any interactive routing feature) to work.  I will have the interactive mode to push or hug and push and you can just go right over other tracks like it is on ignore all.  If I pick up a component it will push the other components but not when doing traces.
Any ideas?  |O
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Push routing not working in Altium
« Reply #1 on: November 21, 2016, 09:30:21 am »
While routing, hit SHIFT+R. (Press ~ for other options.)
Seven Transistor Labs, LLC
« Reply #2 on: November 21, 2016, 03:17:10 pm »
Holding shift and R doesn't do anything except for change the mode.  The walkaround objects seems to work but push doesn't push anything.  :'(
Offline T3sl4co1l
« Reply #3 on: November 21, 2016, 03:58:00 pm »
The traces are all on a copper layer, have a net assigned, and aren't locked, right?
« Reply #4 on: November 21, 2016, 04:21:00 pm »
Opened a service request with Altium, they responded within 4 minutes!!  I had my clearance rule set to differential pair only instead of different nets only.  Now it works like a charm!
