Author Topic: Poly Pour Undo??  (Read 6616 times)
Offline skeematics21Topic starter
Poly Pour Undo??
« on: January 30, 2014, 03:44:33 pm »
How do i undo a poly pour? I need to add new traces and components.
Offline Mat
Re: Poly Pour Undo??
« Reply #1 on: January 30, 2014, 04:05:57 pm »
Tools -> Polygon Pours -> Shelve,  to be able to edit your traces, then Restore and Repour.
« Reply #2 on: January 30, 2014, 04:09:11 pm »
Thanks for the prompt response and your help!!!
Offline reagle
    • KuzyaTech
« Reply #3 on: February 01, 2014, 04:35:34 am »
Also, right click and do Shelf Selected. That way you can only shelf one instead of all
Offline DerekG
  • Country: nf
« Reply #4 on: March 12, 2014, 11:50:00 am »
As Altium have progressed through their new releases, I have found that the removal of old polygon pours have sometimes not gone smoothly.
I therefore recommend that you firstly save your finished design without the polygon pours. Then apply the polygon pours & save as (for example) yourpcb_polypours
Just my 2c worth.
I also sat between Elvis & Bigfoot on the UFO.
Offline mrflibble
« Reply #5 on: March 12, 2014, 12:46:32 pm »
I always save & commit to subversion before I do anything polygonish in altium. Definitely more reliable than hoping the undo works 100% all the time. That, and sometimes it's less work too than trying to get back to the last okay state.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: March 12, 2014, 02:27:41 pm »
...removal of old polygon pours have sometimes not gone smoothly.
i think theoritically this is bad... what if after polygon pour you want to change/add/delete your traces? from what i can think of you can either:
1) go back to previous version (the one without polygon pour), re-trace, re-subversion and re-create polygon. which i believe is not nice.
2) continue with latest version, delete polygon and re-trace and re-create polygon again, which is still not nice, or continue with polygon pour, re-trace and the not 100% undo/operation.
Offline mrflibble
« Reply #7 on: March 12, 2014, 02:50:52 pm »
Are you one of those mutually exclusivists I keep hearing about? Using a repository to save that known state only gives me extra options from which I can pick the best one to suit the job. It's not as if by using subversion I am suddenly unable to use the undo button. If pressing undo a few times gets me to a reasonable state, I do that. If undo messes things up I can go back to the last known good state. Basically I'll try and pick the option that is the least amount of work to get to the desired end result. And amusingly enough, using subversion results in less work, not more work. ;)
  • Country: my
« Reply #8 on: March 12, 2014, 06:09:00 pm »
my point was not about the way you do it. my point was about the "How do i undo a poly pour" not going smoothly in Altium.
Offline mrflibble
« Reply #9 on: March 12, 2014, 06:23:18 pm »
In which case I probably didn't quite understand your reply.
At any rate, a subversion commit before a poly pour (or any other large operation) is quite handy.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: March 12, 2014, 11:35:50 pm »
Hmm, never had any problems with polys, beside the fact that Altium handles them very clunkily.  You can (usually?) route traces over a polygon as if it's not there, and repour as needed (always remembering to repour before generating fab files! argh!).  In my flow, I only shelve to get the damn things out of the way (visual clutter, and also moving things around, layout and routing).
If you have overlapping polys, one will pour over the other and the overlapping area can be indeterminate.  To fix this, repour all, and set the pour order in the Manager (T, G, M).  Or just try to avoid overlapping polys.  I find this most useful when placing polys on a layer with a ground pour; the smaller polys need to pour first, otherwise the ground poly fills in and nothing works.
I don't see any reason one should be handling polys by lucky saves and moving junk around.  That sounds fantastically fragile.  It is literally my business :) to address or prevent situations with unwanted memory, hysteresis, undefined quantities and so on.  Polys can be one such example, and approaching them in a way that prevents these unwanted aspects is the best approach.
Seven Transistor Labs, LLC
Offline gxti
« Reply #11 on: March 13, 2014, 05:14:04 am »
Yeah I have no idea what they're jibbering about. If I need to change something, which I do because I'm borderline obsessive about tweaking traces incessantly, I just shelve tweak and unshelve and it repours everything. No trouble at all. I do it so often, in fact, that I'm irritated that some of the steps do not have shortcut keys.
The pour is disposable, the important bits are the rules that were used to pour it in the first place, and they don't go anywhere when you shelve.
Offline Araho
  • Country: no
« Reply #12 on: March 18, 2014, 03:57:12 pm »
+1, same as I do.
