Author Topic: Find IC footprint  (Read 3668 times)
Offline alamwteTopic starter
  • Country: af
Find IC footprint
« on: October 22, 2021, 11:16:04 am »
Hello,
I have a question.
What is the true way of finding a PCB footprint of ICs?
 For example I can not find the IC's footprint by its part number. But I know it is a QFN 56 7x7 .
How can I find the standard dimension of these packages to build its footprint by my own?
I have found many dimension for this package!!
I even found different footprint in Snapeda.com
please guide me,
Thanks ,
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Find IC footprint
« Reply #1 on: October 22, 2021, 02:17:49 pm »
If the manufacturer doesn't include the footprint information in the datasheet, they usually include at least the internal package name/drawing number. When you go to the manufacturer's website or do a careful web search you should be able to find the drawing of the footprint.
As you have discovered there are many QFN56 7x7 packages. If there is a drawing of the geometry of the physical part, QFN's are easy to make footprints for from scratch.
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: alamwte
  • Country: af
« Reply #2 on: October 22, 2021, 04:54:24 pm »
In its  manufacture's site is just written its package is QFN56 7x7.
Now I want to find out where can I find its dimension ?
Is there any site that I can find the QFN packages standards?
I have found some different dimension of this package in every site. for example in nxp.com and ti.com or FTDI.com it has different dimension.
Thanks,
Offline thm_w
  • Non-expert
« Reply #3 on: October 22, 2021, 08:29:27 pm »
Yeah but is it close enough that it would work, thats all that matters.
  • Country: af
« Reply #4 on: October 22, 2021, 08:49:51 pm »
OK, thanks
