Author Topic: Alternate Part variant keeps updating PCB  (Read 2120 times)
Offline DutchGertTopic starter
« on: November 18, 2015, 02:01:53 pm »
Hey guys,
I have a weird problem that I don't understand when using Alternate Part variants in Altium 16.
I have an FPGA design where I want to use variants to choose between different variants of the same pin-compatible part (Zynq Z-7010 and Z-7020 in CLG400 package).
The only difference between the parts is one of the banks of the FPGA that is N.C. in the Z-7010 part and has usable I/O in the Z-7020 part. PCB wise the parts use exactly the same footprint.
What happens is that when I select the alternative part, Altium correctly switches between the two selected components when I select the corresponding variant. However, each time I update the PCB from the schematic  it reconnects a lot of the pins of the part... Afterwards everything is still the same and connected correctly (as expected) but it keeps finding changes and updating the PCB each time I  "Import changes from ..."
Does anyone have an idea what is going on here and how to solve it? Thx
