Author Topic: AD 15, solder mask expansion on tracks  (Read 2322 times)
Offline linux-dudeTopic starter
  • Country: ph
« on: November 19, 2015, 03:11:32 pm »
I've been scratching my head for quite a while, maybe someone have solved this.
I'm trying to figure out a way to make solder mask expansion on *tracks* controlled via rules.
I have set up a rule that for a specific class set solder mask expansion to 20mil. But for that value to be enforced, i must first route the track and then select every track in the class and in the Track Property dialog | Solder Mask Expansion, enable "Expansion From Rule". I've tried to change default track to have this option enabled, but all new traces are created with the option disabled. Is there a way to force AD to enable "Expansion From Rue"?
Thanks in advance
Online T3sl4co1l
    • Seven Transistor Labs
Re: AD 15, solder mask expansion on tracks
« Reply #1 on: November 19, 2015, 07:48:00 pm »
Don't know offhand.
You can set defaults from the Preferences dialog.  Apparently not everything can be persistently changed from the TAB dialog.
Better selection might help.  Try S (Select), S, C, P, N, etc.
Might also consider using polygons, and drawing soldermask patterns on top of that.  Rather an anti-solution, but can be good for fatter routes.
Seven Transistor Labs, LLC
Offline ajb
« Reply #2 on: November 19, 2015, 10:01:22 pm »
If you've set expansion from rule in the default PCB primitives and it's not actually affecting new traces, I'd call that a bug.
As a slightly easier workaround, perhaps you could use a net class plus a query to select all of the tracks that need expansion and apply it all at once.
  • Country: ph
« Reply #3 on: November 23, 2015, 10:08:21 am »
Thanks for your replies.
I finally gave up on this. Either a bug or me missing something. I learned to use filtering better, so it wasn't so bad after all :D
Offline Richard Head
« Reply #4 on: November 23, 2015, 12:07:09 pm »
On Protel you create a keepout layer. Altium may be similar.
