Author Topic: AltiumDesigner15: Working with complex shapes  (Read 1464 times)
Offline PsiTopic starter
« on: September 12, 2019, 07:19:08 am »
I have some graphics i want to place on my PCB for a logo in Altium Designer 15.
If i try import by copy/paste using a B&W image the quality is bad.  Probably because the source is pixels not vector.
If i try import it as a DXF it works but contains many thousands of super short traces and this slows down Altium to the point of being unable.
Does anyone know a way to reduce the complexity of a region or a outline?
Basically reduce the number of vertices in it. It doesn't need to be super accurate.
Or better yet, any method to insert a graphic on the PCB that results in both smooth edges and doesn't slow down Altium.
« Last Edit: September 12, 2019, 07:21:15 am by Psi »
Online enz
Re: AltiumDesigner15: Working with complex shapes
« Reply #1 on: September 12, 2019, 09:35:40 am »
I typically convert logos to TrueType fonts. This delivers me a vector format and makes the logo easily scalable.
I used two different programs in the past.
1. FontForge: free, but a little bit difficult to use for a first time user (or for seldom use).
2. FontCreator from HighLogic: 49$ / 149$, but there is a trial version available. Much easier to use than FontForge, in my opinion
Maybe there are other programs which can vectorise a picture into a true type font.
Offline tszaboo
« Reply #2 on: September 12, 2019, 10:54:39 am »
There is a script to import. It turns it into horizontal lines.
Here is an example.
https://www.pcbyes.com/index.php?route=information/news&news_id=9
After that, you can group the lines, or convert it to a region (if it is supported in 15 already).
« Reply #3 on: September 12, 2019, 12:35:45 pm »
Thanks, i'll try both those ideas and see how it goes.
« Reply #4 on: September 13, 2019, 01:04:02 am »
I tried FontForge and made myself a font with the symbols to test it out.
This part worked fine.
I now have a font with the symbols for 01234 characters.
I can use the font in word/notepad and it all look great at 120pt size etc..
But if i use that font in Altium it looks pretty terrible,  like Altium has 'simplified' the font.
Any ideas?
« Reply #5 on: September 13, 2019, 01:08:31 am »
Nevermind,  I had the Altium text set to BOLD     :-DD
Looks good now :)
Online enz
« Reply #6 on: September 13, 2019, 08:53:30 am »
Glad I could help
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: September 13, 2019, 04:33:14 pm »
Also, Tools/Convert/Outline to Region?  Forget when that was introduced, but it's in 16 at least.  There's also a script that converts BMP to Region somehow.
Seven Transistor Labs, LLC
