Author Topic: PCb stackup regions - round Split line for battery contact  (Read 3059 times)
Offline rflemingTopic starter
« on: August 23, 2021, 02:50:05 am »
Hi All, I am trying to create a basic PCB that has a few different pcb stackup regions. Regardless of the "cost" of how specialised this pcb is, I am more or less hoping that I can create split lines on my board that are not straight lines from the outline layer.
As you can see from the images, I am trying to steer away from these straight line region changes. These parts, while they will be "flexible" are not intended to actually flex.
FYI, this is a 4 layer board and I am just using the 2nd signal layer with a ground plane since altium wouldn't let me put a prepreg layer below my bottom layer :(
This is quite a "bespoke" application and I don't have too much wriggle room. My alternative solution is just to go back to using a ground battery terminal. But due to my flex requirements, I am already using prepreg between these layers so I thought I might be able to use it as the battery ground terminal instead of soldering an actual part in production.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: PCb stackup regions - round Split line for battery contact
« Reply #1 on: August 24, 2021, 04:44:09 am »
Better place to ask would be your PCB fab house of choice, for example Wurth have their rigid/flex combo quite sorted out
https://www.we-online.com/web/en/leiterplatten/willkommen_/Willkommen.php
« Reply #2 on: August 24, 2021, 07:05:43 am »
Unfortunately, fundamentally the software doesn't let me. So the best I could do is create a custom layer and try to convey that to the board house of what I am trying to do :(
