Author Topic: How to edit the defaut PCB grid presets  (Read 6219 times)
Offline nikifenaTopic starter
  • Country: bg
« on: November 26, 2021, 09:41:59 am »
Hi there. I have an old AD17. Usually, I use "G" on the keyboard to get this menu. Unfortunately, some of the grids used by me are not here and I don't need some of the stocked. How can I edit/modify this set of grids with my own?
Thanks
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: How to edit the defaut PCB grid presets
« Reply #1 on: December 07, 2021, 12:15:45 am »
Just press G twice and type in your desired grid.
“They Don’t Think It Be Like It Is, But It Do”
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: December 07, 2021, 01:37:24 am »
CTRL+click on the offending menu item.  You can edit the command and title (and shortcut: '&' underlines the following character) in the dialog.
(Not sure if this has changed since AD18 or 20, but customizable menus have always been a thing in any case.)
Seven Transistor Labs, LLC
The following users thanked this post: nikifena, ANTALIFE
  • Country: bg
« Reply #3 on: December 07, 2021, 06:28:58 am »
Thank you T3sl4co1l!
Yes, that's what I wanted!
Just one more question - how can I delete the unused presets? I've been using the metric grids only and the imperial are messing me.
Thanks
Offline T3sl4co1l
« Reply #4 on: December 07, 2021, 08:39:48 am »
DXP menu (user button now I think?), or right-click toolbar/menu area, Customize.  Look for "Snap Grid".  Have fun. :)
It's a not well known/understood/appreciated/used feature, I think?  Granted, there's more than enough functionality in AD just to get used to in the first place, remembering all the default menus as they are, let alone the shortcuts, let alone customizing your own.  There are just a handful of changes I've made, to this day.  Potentially very powerful feature... or dangerous too, hehe. :-+
Offline snoopy
    • Analog Precision
« Reply #5 on: December 27, 2021, 03:19:10 am »
This is what I did. Right Click on the menu bar and select Customize.
Look for "Snap Grid" in the left hand Commands list box. Then select a grid that you would like to copy from the right list box to customize ie to create a 0.05 mm grid click on 0.025 mm and then click the "Duplicate" button. It will then create a new [Custom] category in the left hand list box with a copy of the 0.025 mm grid option. Find this new [Custom] category and click on it and you will see the copied 0.025 mm grid setting. Double click on this and change the 0.025 mm parameters to 0.05 mm. Once you have done this you have to drag this new category with the a left mouse click to the "PCB Popups" menu and then insert it into the "Snap Grid" menu at the appropriate place.
regards
david
The following users thanked this post: Someone, georgd
Online Someone
    • send complaints here
« Reply #6 on: March 01, 2024, 02:33:53 am »
That "PCB Popups" menu that appears is extremely useful and I only found it through your post. It can be used to add some extra grid sizes on preferred increments as you did, but it is also possible to delete unwanted default grids. Or remove other menu items on the context popups that are on that list (not all context menus are within there, but still very handy).
