Author Topic: (Altium Designer 19.1) How to get document parameters to apply?  (Read 6238 times)
Offline 0culusTopic starter
« on: November 20, 2019, 05:29:34 am »
I'm relatively new to Altium, picking it up to facilitate collaboration with a friend on some (noncommercial) projects (student licenses FTW). I've been working on learning the basics, have schematic generation down pretty well. One thing I cannot figure out though, is how to change the title and stuff on a schematic sheet. I finally found the document options (they moved it sometime before version 19 it seems), but updating the parameters seems to have no effect on the document. Refreshing doesn't seem to help either. How do I do this simple thing????
« Last Edit: November 20, 2019, 05:34:08 am by 0culus »
Offline pigrew
Re: (Altium Designer 19.1) How to get document parameters to apply?
« Reply #1 on: November 20, 2019, 05:42:57 am »
As I remember, the default sheet template does not include the "parameters" for Title, etc. One has to manually put the texboxes in the proper places....
There are a few included sheet templates that do use parameters, or you can design your own template. If a text field starts with an equals sign (like "=Title"), it'll do parameter replacement.
I agree, it isn't user friendly.
« Reply #2 on: November 20, 2019, 05:49:13 am »
Thanks! That's...super lame. Guess you can't have everything. On the whole, it's not a terrible piece of software; actually fairly well polished aside from edge cases like this. I've used far worse (and far more expensive) specialty software at work. The particular example I'm thinking of costs >50k USD per seat and is absolute garbage in terms of UX and stability.
Offline Bud
« Reply #3 on: November 20, 2019, 06:21:48 am »
You can either place text labels that have "=Parameter" in it , where Parameter is the name of the parameter you edit in Document Options. Or open and edit a template (.schdot I believe) , do the same thing in the template, save it and then apply that template to the schematic sheet, again in Document Options->Templates.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: November 20, 2019, 06:52:00 am »
Oh you'll find plenty more edges, this is nothing. >:D
Yeah, the templates are pretty flexible, give a look through the built-in libraries (I don't know where they're putting them these days; used to be installed under Public Documents), there are some templates in there I think.  You can open templates as-is, and see the objects in them, and see what special strings they use.  Or open them as new schematics (the templated stuff is inaccessible) and use them.
Seven Transistor Labs, LLC
Offline SerieZ
  • Zap!
« Reply #5 on: November 20, 2019, 12:45:44 pm »
I agree that Altium could provide a better default sheet.
However of the many rough edges Altium does have I feel like this is not really one of them.
Ive made myself a template a long time ago, with thought out parameter established (some been removed or added over time) and I am now happy I can quickly start a new project with a simple "works for most-(but customizable)" template I made myself and which looks really neat and professional.
As easy as paint by number.
« Reply #6 on: November 20, 2019, 04:01:53 pm »
I've yet to find any piece of software that doesn't have some kind of "wtf were they thinking" type of annoyance.  :palm:
I was able to get what I wanted by switching to the `A4' template available in the default list. I will probably work on creating my own that can use parameters.  :-+
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #7 on: November 20, 2019, 10:03:15 pm »
Parameters and templates are very powerful time savers in terms of new documents, and output generation. The way I have them setup is all of my parameters only exist at the project level. This way you only need to go to one location to update all the relevant information for any given project. The project parameters can flow down into each document (schematic, pcb, draftsman, etc), it is absolutely fantastic. And when i go to generate a document package, I hit one or two buttons and the file naming is generated via the parameter information as well. Very streamlined, I think it could be one of altium's best features.
For file naming you can make concatenated expressions like this:
=assm+'.'+printassmrev+OutputName
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: thm_w, Bud, 0culus
« Reply #8 on: November 20, 2019, 10:13:27 pm »
Would you mind sharing how to set that up? That sounds very powerful and useful.  :-+
Online T3sl4co1l
« Reply #9 on: November 20, 2019, 11:37:19 pm »
A caution about parameters in OutJobs: when copying the file to another project, the parameters aren't updated (again, at least in v16 and thereabouts).  So you can get weird behavior before filling out project parameters.
Offline Pseudobyte
« Reply #10 on: November 21, 2019, 02:36:13 am »
sure I can throw together an example project for everyone
The following users thanked this post: julianhigginson, 0culus
Offline Pseudobyte
« Reply #11 on: November 21, 2019, 08:17:21 pm »
I didn't do all the work for everyone :). But i did list all the parameters that I use, so you might be able to get an idea of what I do. I included two outputs. If you have any specific questions I would be happy to answer them via PM.
The following users thanked this post: thm_w, 0culus
