Author Topic: Clearance rule problem...  (Read 11199 times)
Offline Mad IDTopic starter
« on: April 13, 2013, 11:48:11 am »
For my current project I have to use dozens of net classes which have clearance rules between each other.
I have created net classes with schematic directives and have defined electrical clearance between them with PCB rules:
Where the first object matches: InNetClass('XY');
Where the second object matches: Not InNetClass('XY') or InNet('No Net')
This worked out well until new problem appeared. Now I have a problem with "No net" pins that have a smaller clearance to the other objects (pads and tracks) than it is defined by the clearance rule.
I have tried to define additional rules (with smaller defined clearance):
Where the first object matches: InNet('No Net')
Where the second object matches: Not InNet('No Net')
also I also set that rule as a priority rule, but it doesn’t work either.
I searched for a solution but I couldn’t find any, so hopefully someone here can help me.
Thanks in advance
« Last Edit: April 13, 2013, 11:49:59 am by Mad ID »
Offline free_electron
    • SiliconValleyGarage
Re: Clearance rule problem...
« Reply #1 on: April 13, 2013, 01:43:27 pm »
You dont need that second clause. That is most likely the cause of the trouble.
If innet nonet. This clearance.
« Reply #2 on: April 13, 2013, 06:35:57 pm »
I already tryed that but it hasn't worked out.
Any other suggestion/solution?
Below you can see what is the main problem:
Offline Rufus
« Reply #3 on: April 13, 2013, 07:50:17 pm »
I'm not sure what you are trying to achieve or exactly what your problem is.
I can say that NoNet isn't a real net because all NoNet objects would be connected if it were. I am pretty sure InNet('NoNet') doesn't match objects with no net.
You could try ((Not InAnyNet) And IsPad)
« Reply #4 on: April 14, 2013, 02:19:43 pm »
Thanks a lot! That is exactly what I was looking for! :-+ :-+
