It’s time for my Altium subscription renewal and my question is to renew or not to renew.
I'm still on Altium Designer v 6.9. I paid AUD$3600 to upgrade from DXP as they promised the full screen scroll problem (present since Protel ver 2.5 in 1995) was fixed along with what you see is NOT what you'll get (you have to check your board in single layer mode to ensure what you see in all layer mode is what your board will actually be).
.............. well, Altium only gave me half full screen mode (their fix to their one direction non-scrolling problem) by leaving the scroll bars & the WYSIWYG problem remained unchanged.
I felt duped (actually I was duped).
Bugs should be fixed not based on subscription as this would mean you purchase a faulty product and pay a subscription to fix it.
But unfortunately that's not how Altium operates. In Australia at least it could even violate "fit for purpose" laws if you are sold a dud version and they won't fix it unless you pay for subscription.
Many pro Altium users get a stable version they are happy with and then stick with it and drop the support. There are still many people using 99SE for that reason. If it ain't broke, don't fix it.
Yes, if the current version does all you want then there is little reason to upgrade. Australia's fit-for-purpose laws are much stronger now than in 2008 when I took my last upgrade. With the Altium email saying my 2 big gripes had been fixed (when they weren't), Altium would have nowhere to go but to upgrade me to a (fixed) later version at no cost.
I'm up for renewal in Feb. I'm also having a hard time justifying it, as well. I'll have access to 14, but 13.3 has been stable and as much as I need.
The AD14 designator is just referring to the year 2014. There is no reason to suspect it will have significant problems over AD13 ................ however if you have access to it before your subscription falls due, download it & you then have both copies just in case it turns out to have some major bugs.
Couple of questions I'm trying to work through in deciding to punt the subscription.
How does re-installing Altium work if you don't have a subscription?
Does it just allow you to download the latest version you had access to when your subscription ran out?
Whilst your subscription is active, ensure you download the latest updates. Place these safe with your original purchase so you can re-load onto a new machine if needed. The licence (used to be at least) is perpetual, so as long as Altium can find your original license in their database, all will register again via the net. If you run into a problem, you can always call up their local office & demand it be fixed.
Take a screen shot from "Help" "About" as this proves your license is "perpetual" (used to be at least).
I use the software as it is quite powerful compared to many others ............... however I dislike the software & I dislike Altium as a company as well ............... just pointing it out in case it was not very evident.
