Author Topic: Purple pads , no other layers visible  (Read 1613 times)
Offline strawberryTopic starter
  • Country: lv
« on: November 01, 2016, 12:23:22 pm »
Did I broke Altium?
All layers turned on
Offline vzoole
  • Country: hu
Re: Purple pads , no other layers visible
« Reply #1 on: November 01, 2016, 07:20:08 pm »
Maybe press 'Clear' (right down).
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: November 02, 2016, 05:10:58 pm »
SHIFT+C (clear mask),
SHIFT+S (toggle single layer mode),
Numpad + or - or * (change layers, or select layers from the tabs along the bottom)
Also check that other layers are enabled (leftmost tab, or Design / Manage Layer Sets).
Also check that the layers are not all colored purple ('L' or D, Y -- Board Layers and Colors). :P
Seven Transistor Labs, LLC
Offline DutchGert
« Reply #3 on: November 04, 2016, 01:38:29 pm »
U just discovered a very handy feature ;)
