Author Topic: Interactive length tuning  (Read 3342 times)
Offline PlectoTopic starter
« on: September 08, 2017, 07:04:13 am »
Hi. Neither interactive length tuning or interactive differential length tuning seems to be working. I've watched several guides and tutorials and they all say that I'm simply supposed to click 'interactive length tuning', click on a trace and move the cursor. I've set it to manual, set a target length that is longer than the current track length and I've messed around with all kinds of pattern values, but nothing happens. Differential length tuning does nothing as well, even though I've specified a differential pair class and rules (I'm getting unmatched net length warnings). What's going on?
Re: Interactive length tuning
« Reply #1 on: September 14, 2017, 06:36:26 am »
Anyone?  :(
Offline defter
« Reply #2 on: September 14, 2017, 08:52:28 am »
hi,
hit TAB key during interactive length tuning and try to modifie the parameters. Gap values and amplitude. You can also change these by shourtcut (1,2,3,4 dot, and comma). If nothing happens usually just these parameters are incorrect, or there isn't enough space. Try to set target length to manual and set the value by hand and not from the rules.
