Author Topic: How to get rid of xsignals highlighting?  (Read 2302 times)
Offline AmazingTopic starter
« on: June 25, 2017, 09:54:25 pm »
  Do any of you know how to turn off the highlighting that shows which xsignals trace you are looking at?
  Once I've clicked on an xsignal, the only way I can find to get rid of the highlight is to close the file.
  I'm still on 16.
  Thanks!
Offline kiran_shrestha
  • Country: kr
  • Kiran
    • shorted wire
Re: How to get rid of xsignals highlighting?
« Reply #1 on: June 27, 2017, 07:35:04 am »
I think clear filter will work ( shift + C ) otherwise go to x signals list from the drop down and try highlighting some other signal.
Thats all
« Reply #2 on: June 29, 2017, 01:19:55 am »
Clear filter doesn't clear it.  Highlighting some other signal works but then I've just got that
signal highlighted.
Offline Randy_Clemmons
« Reply #3 on: July 03, 2017, 08:30:30 pm »
Go back to the PCB Panel and Select Nets (Not xSignals) then select clear.
I agree with you, clear should un-highlight the selected xSignals
« Reply #4 on: July 03, 2017, 08:35:47 pm »
Thanks!  That did the trick.
  • Country: kr
  • Kiran
    • shorted wire
« Reply #5 on: July 04, 2017, 05:34:44 am »
Ha ha  :-DD that's what I said too in the second option ...
Thats all
