Author Topic: version  (Read 2544 times)
Offline zeinabTopic starter
  • Country: ir
version
« on: July 08, 2017, 07:14:05 am »
Hi
i want to add a version code on my pcb automatically like insert picture, how can i do ?
i work with altium 17,and vault3(i recently worked with this software)
Online T3sl4co1l
    • Seven Transistor Labs
Re: version
« Reply #1 on: July 08, 2017, 05:01:43 pm »
I normally add a parameter.  Set the text label to ".Revision".  Under Project Options, Parameters tab, create a "Revision" parameter, with value "1" (or whatever your current revision is).
Use the same parameter on schematics with "=Revision".
I'm not sure if parameters can be referenced from database or anything.  (If you want to write a script, anything is possible?)
Seven Transistor Labs, LLC
The following users thanked this post: zeinab
  • Country: ir
Re: version
« Reply #2 on: July 10, 2017, 12:11:27 pm »
thanks for tips,
i have done  this for my schematic sheet ,who can i add this version for pcb sheet without use (place, string and change manually string )
i work with altium vault, i hope to insert version to pcb sheet automatic with altium vault
