Author Topic: Cannot Edit Text Width Parameter  (Read 2378 times)
Offline dlmmartinsTopic starter
  • Country: br
« on: January 06, 2017, 04:25:01 pm »
Good morning Srs,
A new doubt. On PCB, I would like to edit the parameter "width" of the designator text of the components.
I used the PCB Inspector, and it selected all the same components for editing. I can edit the size and other parameters.
However the width the text it does not allow. The "width" line is greyed out and does not allow editing.
Do you have any solutions for this?
Greetings,
Offline kiran_shrestha
  • Country: kr
  • Kiran
    • shorted wire
Re: Cannot Edit Text Width Parameter
« Reply #1 on: January 08, 2017, 02:46:03 pm »
I think you have mistakenly selected some other items in PCB.Try this
1) use command isDesignator hit enter
2) CTRL +a
3) Now check whether the width is still grayed out
Thats all
