is there fast possibility to make a named polygon using direct connection and another clearance? For instance:
I got converter MP3414 nad instead of routing it normally it would be better to make those connections (with inductor, caps and so on) using a polygon.
Now I am doing it by writing rule like: InComponent('U7') or InComponent('L1') etc. but it would be more convenient if I could write: InNamedPolygon('MP3414_Inductor'). It obviously doesn't work, as in the screen below.
Maybe you have some other "pro tips" for noobs like me?
