Drifting offtopic, but, generally with CAD software you have the entire project team on the same software version as a rule.
Solidworks won't even let you work cross-version, you'll get locked out of the file.
Altium is kind of the exception to this, where you can actively work on older/newer file versions.
Have you tried using a network path thats not mapped to a drive letter? eg //Network_Share1/asd/
Although I'm assuming this is shared folder, but, it sounds like you are using a synced repo instead.. hm
