Author Topic: Clearance Rules Pad and Wire  (Read 899 times)
Offline guest_VRTopic starter
« on: June 22, 2022, 07:12:03 am »
Hi everybody,
I try to use different clearance rules on different layers.
Such as " (OnLayer('Layer 2') AND InNetClass('Logic'))  " and "(OnLayer('Layer 2') AND InNetClass('HV')) " : 3mm clearance.
so far it acually works all right for the wired nets, but not for the PADS and vias.
The pictue below shows Layer 2 and i am missing the 3mm around the pads and the via i placed in the middle of them!
Does anyone has an idea why it is like that?
Thx for your help
Re: Clearance Rules Pad and Wire
« Reply #1 on: June 26, 2022, 07:30:25 pm »
That was very helpful - I missed that Pads are multi-layer objects.
But now it works - thx for your help
