Author Topic: Help out a beginner with altium !  (Read 15109 times)
Offline ultrathomTopic starter
« on: January 08, 2014, 10:34:19 am »
Hi everyone I just got a copy of Altium 10 and I need some help getting started designing a schematic.
1.
The first issue I came across is placing a 100nf capacitor. In the libraries I searched Misc.Devices. IntLib and could not find many capacitors at all. I see only 8. Am I supposed to use this as a template and edit the value manually ? I thought that defeats the purpose since every part is so specific. So I added this
http://techdocs.altium.com/display/ADOH/Download+Libraries
But now I have a large number of footprints from various manufacturers but not sure where to look for a capacitor ?
2.
I need to place a PLCC44 socket. I have the pinout for the IC that will populate. Should I put a footprint for the PLCC socket on the schematic ? Then assign the pins ? Whats the best way to go about that ?
3.
How do I define voltage and ground lines on the schematic ?
4.
How do I create a bus of 8 signals ?
Thanks all !!
Offline Spikee
Re: Help out a beginner with altium !
« Reply #1 on: January 08, 2014, 11:54:56 am »
1.
For smd size components this library is nice:
http://www.siliconvalleygarage.com/downloads/altium-library.html
Normally you make a footprint and add the supplier data to the component. Than it takes all the parameters from farnell/mouser/digikey ...
2.
I would make a new footprint for the socket , and just name the nets in the schematic like they are on the IC , not in the *.SCHlib.
3.
Anything positive is mostly named VCC and then your voltage "VCC6V3" Digital ground is mostly named VSS
4.
Just use "place a bus"
http://techdocs.altium.com/display/ADRR/Sch_Obj-Bus((Bus))_AD
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
« Reply #2 on: January 08, 2014, 01:04:20 pm »
Ok, Thanks for that lib i found a 100nf Capacitor. Where can I find the PLCC44 socket ? I think I found a footprint but I cant drag it onto the schematic like a part, and it shows a PLCC44 IC not a socket. Is that the wrong part ? Should I get a picture of a socket ?
Offline Spikee
« Reply #3 on: January 08, 2014, 02:50:04 pm »
I think it is best to make your own footprint.
« Reply #4 on: January 08, 2014, 04:23:23 pm »
Not really confident in that yet, how would I go about doing it ?
Surely there is a file I can download with the specifications of the part and I can just import and place it ? For such a common socket
« Reply #5 on: January 08, 2014, 04:37:23 pm »
1. If I create a bus, and define say 8 vertices (I assume thats wires in the bus) then want to split the bus so I can attach the wires onto the IC, how can I do it ?
2. If I want to have a bus linked but not draw it on the schematic, that is terminate at a point but reappear somewhere else without linking it directly, how do I go about that ?
I have attached what I am trying to connect up to illustrate. This is repeated a number of times in the schematic so I want to make one version then copy it and change the bus numbers etc.
« Reply #6 on: January 08, 2014, 05:41:22 pm »
Also in the schematic I see a different notation at the end of wires AX0 through AY2. What is that symbol > suggesting ?
Offline cwalex
« Reply #7 on: January 08, 2014, 10:22:32 pm »
There are some pretty good tutorials on youtube. I like this guys
« Reply #8 on: January 09, 2014, 12:46:21 pm »
Making progress, that video was very helpful Thanks
I have run out of space in the schematic. How do I make the sheet bigger ?
I found a footprint for the part but the spec sheet does not specify which of the three possible footprints I should use. Those are N44.65_L (IPC high density), N44.65_M (IPC low density), N44.65_N (IPC medium density). All it says on the sheet is 44 Ld PLCC (SGS Ld Compatible).
Also I can't drag the footprint onto the schematic, do I edit it first ? Then save as a part somehow ?
Offline graynomad
« Reply #9 on: January 09, 2014, 01:52:23 pm »
Right click on the sheet then
Options > Sheet...
Normally you would assign that footprint to a schem component first, but you can add a footprint directly to a PCB, in the PCB editor type P then C (Place component) then use the dialogue to select your footprint.
______
Rob
Graynomad, AKA Rob Gray www.robgray.com
« Reply #10 on: January 09, 2014, 03:16:23 pm »
Ok sheet is bigger. Still cant place the footprint, place is greyed out in the options. How can I take that footprint and make it into a component I can drop into the schematic ? The first issue is I'm not sure which of the three footprints is correct. Then I want to put this IC into a socket so is it better to put the PLCC44 socket onto the schematic and link the bus to that ? These parts are actual IC's and I want sockets. Finally not sure where to find sockets, what library.
Also how can I split a bus into its component wires for connection to the IC and then terminate the bus as in the schematic ? Like you might with a ground symbol
Offline graynomad
« Reply #11 on: January 09, 2014, 10:10:56 pm »
So PC doesn't work either?
I have no idea why, maybe I had a similar problem at first because there was no library for the project, but that was years ago and I have forgotten. So you created a project, then created a new PCB then did PC and it didn't work? I just did that and it did so that's about the limit of my knowledge for this.
I doubt you will find a PLCC socket in the standard libs, I find the easiest thing is to make the footprint manually then grab a 3D model (from http://www.3dcontentcentral.com/) and place that on your pads as a sanity test.
You almost never put a socket on a schematic, you place the chip and the chip's footprint is the socket.
Place > bus entry
Not sure what this means, AFAIK you don't terminate a bus as such, you terminate all the signals in the bus I guess. What is this for, pullup resistors or something?
______
Rob
« Last Edit: January 09, 2014, 10:32:55 pm by graynomad »
« Reply #12 on: January 10, 2014, 09:26:47 am »
Thanks that's helpful
Place > bus entry
This draws a tiny diagonal line, I'm not sure what to do with ?
Feels like I almost know enough....
Really don't want to draw that footprint myself. One mistake in spacing and I have to refab the PCB.
« Reply #13 on: January 10, 2014, 09:40:26 am »
 :scared: $20 pp to anyone who can make the part for me so I can just drop it to the schematic
Not sure if that's too much or insultingly low.
Offline graynomad
« Reply #14 on: January 10, 2014, 09:50:13 am »
Here's an example of using a bus and the bus entry thingies.
TBH I think it's just a visual thing and labelling the nets would do the same as far as the software is concerned. But using a bus shows you exactly where the signals go. I may be wrong about that but I can't see that it does anything else.
I'll do the component, no guarantees it will be correct though.
EDIT: SMD or through hole? Do you have a particular socket in mind?
_______
Rob
« Last Edit: January 10, 2014, 09:53:22 am by graynomad »
