Author Topic: How to assign Pin to a solid region  (Read 2865 times)
Offline alex934Topic starter
« on: December 14, 2016, 05:46:00 pm »
Hi everyone,
I need to design an electrode so I did my footprint using solid region. I would like to assign to my solid region two pins, my problem is when I use it in my design it's like there is a problem.
I tryed to do >>design >> netlist >> update free primitives from component pads  but it doesn't change anything
Thank you
« Last Edit: December 14, 2016, 05:47:53 pm by alex934 »
Offline free_electron
    • SiliconValleyGarage
Re: How to assign Pin to a solid region
« Reply #1 on: December 14, 2016, 06:09:39 pm »
make sure your region COMPLETELY overlaps your pins. make those pins like 1mm by 1mm.
the region essntially neds to cross the hotspot of the pad. if not you get this behavior. a connection is only valid if it crosses the hotspot.
in 17 they have  new rule and a glosser to fix such problems automatically
« Reply #2 on: December 14, 2016, 06:37:53 pm »
Hum it's still the same the pin is completly in the solid region.
Maybe it's because I superposed several solid region?
Offline tautech
« Reply #3 on: December 14, 2016, 07:11:46 pm »
Have you assigned a Net name to the pins/pads ?
Should be the same as the same of the Net/s you are trying to connect to.
« Reply #4 on: December 14, 2016, 07:20:09 pm »
Well when I connect something in schematic, the problem disappears...But I don't really understand
« Reply #5 on: December 15, 2016, 06:04:10 pm »
of course. if nothing is connected to it the no net gets assigned and you get a short circuit violation ! that is normal behaviour
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: December 15, 2016, 06:33:08 pm »
To do the same thing, you can add wires to the pins, and put net labels on them.  You get "single pin nets", which are disabled by default under Project Options.
The DRC eval for "No Net" copper is kind of weird, but it has its purpose I suppose.
Remember too, you can always use the fab outputs, whether the DRC is there or not.  If the copper is correct, nothing else matters.
Seven Transistor Labs, LLC
