I will start by saying I know workarounds for this issue. I'm curious why this feature (or lack of) doesn't work.
I want to route an RF line with a rounded corner. So I set the constraint for the net class containing my RF nets (see first image)
Then when routing using interactive routing, I can only get 45/90 routing. No rounded corners (second image.) When I look it up in the docs Altium says:
"This rule is intended for use by third party Autorouters that implement 45° routing as a post process. It is not followed by the Situs Autorouter, which implements 45° routing as a native process."
I know how to turn a 90 degree bend into a mitered corner, and I know how to draw an arc. It just seems less than optimal. Am I missing something?
