Author Topic: Multichannel design and copying same layout with polygons  (Read 8465 times)
Offline wekyTopic starter
« on: February 18, 2016, 04:09:27 pm »
First of all i am beginner...
I am designing board with 8 same channels. When i make layout with polygons on one channel and use copy room formats to get same layout on each channel I get collision on copied channels because polygon around D-PAK is connected to NetD1_D08_2 and this same net is copied across all channels as layout. Please can someone refer me how to instruct Altium to do change net for this polygon by automatism?
« Last Edit: February 18, 2016, 04:16:45 pm by weky »
Online T3sl4co1l
    • Seven Transistor Labs
Re: Multichannell design and copying same layout with polygons
« Reply #1 on: February 18, 2016, 04:17:40 pm »
We just had this..?
https://www.eevblog.com/forum/altium/copy-rooms-with-fills-and-poly-pours/
I don't know why it doesn't change polygon properties. If you have auto-repour disabled, maybe Update Primitives from Component Pads will do it automatically?  Otherwise, go through and do it by hand.  Try to avoid tweaking the layout and having to copy and update things again...
Seven Transistor Labs, LLC
Re: Multichannel design and copying same layout with polygons
« Reply #2 on: February 18, 2016, 04:20:52 pm »
Just as I clicked post and got back to main topic, I realized that same topic is few posts bellow...sorry. Thank you for fast reply.
« Reply #3 on: February 18, 2016, 04:33:41 pm »
We just had this..?
To confirm this works for me...
Online T3sl4co1l
« Reply #4 on: October 04, 2016, 10:08:30 pm »
FYI:
I'm doing this today, as it happens.  Turns out it works (v. 16.0+) if you do:
D, M, C
Click a source room, then click a destination
In the dialog, check Copy All Objects Touching the Room
It even clears the old ones, so you don't get a huge pile of copied shapes or anything.  ^-^
