Author Topic: DXP 2004  (Read 4897 times)
Offline GKTopic starter
DXP 2004
« on: June 15, 2012, 02:20:38 am »
Hello all.
Sorry if this is a silly question but in Altium DXP 2004, every time I want to update a PCB document from a schematic file, the "Engineering Change Order" wants to delete all my design rules by default, so with each update I have to un-click about two dozen check boxes. This is annoying. Is there a option or preference setting buried somewhere which I can select to stop it from doing this?
Cheers,
Glen
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline David_AVD
Re: DXP 2004
« Reply #1 on: August 11, 2012, 12:31:45 am »
The design rules shouldn't be affected by an ECO as far as I know.
Are you meaning that some of the component properties or nets are changing?
Re: DXP 2004
« Reply #2 on: August 15, 2012, 02:08:11 am »
Here is the ECO window. Each time I have 25 "Remove Rules" check boxes to un tick.
Offline David_AVD
Re: DXP 2004
« Reply #3 on: August 15, 2012, 03:31:38 am »
I don't have a solution for you, but you know you can right click in that area and select "Disable all of same Kind" ?  That cuts it down to a couple of clicks.
