Author Topic: Problem to make footprint!  (Read 16052 times)
Offline toohec
Re: Problem to make footprint!
« Reply #25 on: November 08, 2013, 08:35:39 pm »
Yes, you just need to remove the silkscreen layer (and potentially some mechanical layers) from your PDF output settings.  Are you using the SmartPDF option? If so, one of the dialog boxes after you begin the SmartPDF output will list the layers to be included.  By right clicking on those layers in the PDF settings, you can choose to add, delete, change the order, change the colors, etc for all the layers.  If you are using the fabrication/assembly output selection from the file menu, those are configured in your project options under the default prints tab.
Offline rozehTopic starter
« Reply #26 on: November 09, 2013, 05:18:35 am »
Turn of the silkscreen layer during pdf creation?  :-//
Thanks guys
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
