This should apply to all versions of Altium since Summer 09.
This also assumes you are using Win7, Vista, or WinXP. It should also work in Win8. (I don't remember where the program is in WinXP.)
1.) Open the Character Map application. In Win7 just type it in the search box on the start menu.
2.) In Character Map, in the Font selection go to Times New Roman.
3.) Scroll down until you find the Omega symbol and select it in the main window of Character Map.
4.) Press Select, then press the Copy button. (The symbol should be in the edit box.
5.) Go to the schematic editor and edit one of your resistor symbols. Paste the Omega symbol into the Value edit box after the other stuff, such as 1K?.
I saw the old post about this, but I thought it would be better to create a new thread. I was not sure about the policies concerning bumping old threads.
