Author Topic: Untented via report  (Read 799 times)
Offline MarkTopic starter
Untented via report
« on: May 23, 2022, 01:02:25 pm »
I would like to create a report showing the x,y, coordinates and net of untented vias (that can be used as test points).
How can this be done in Altium?
Offline tszaboo
Re: Untented via report
« Reply #1 on: May 23, 2022, 02:19:43 pm »
1) You select one. Right click, find similar objects. Set up the preferences of it.
2) OK, now all of them are selected.
3) View -> Panels-> PCB list
4) Show only selected objects
5) Profit?
The following users thanked this post: Mark, voltsandjolts
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: May 23, 2022, 04:02:13 pm »
Query in PCB Filter panel,
IsVia AND NOT SolderMaskTentingBottom AND (AsMils(ViaDiameter) >= 40)
The above method helps you generate the query, a good way to get familiar with the scheme.
And yeah, PCB List is best way to get their properties.  Net, X1, Y1, etc.
Alternately, tag them as Assembly Testpoint - Bottom and get the Testpoint Report in the OutJob or whatever.  This can also be assigned automatically (by rule) from the Testpoint Manager dialog.
« Last Edit: May 23, 2022, 04:04:56 pm by T3sl4co1l »
Seven Transistor Labs, LLC
