Author Topic: Circular ground plane from polygon?  (Read 1710 times)
Offline saratogaTopic starter
« on: July 08, 2018, 01:10:37 am »
I've done this before so I know its possible, but I can't seem to get it to work this time.  I've made a circular PCB defined by a circle.  I click the circle and then choose "Create Polygon from selected primitives".   Then I go to polygon manager (first attached image) and change it Solid copper fill.  Finally I hit repour ... and nothing happens.  I just get a transparent polygon over my layer (second attached image).
What am I missing?
Re: Circular ground plane from polygon?
« Reply #1 on: July 08, 2018, 01:33:31 am »
Closing altium and relaunching resolved the issue.  Apparently it was just a bug in the program.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 08, 2018, 09:20:51 am »
Huh, I was going to say you need a net object connecting to it.  I think that's a Remove Dead Copper thing though.
Seven Transistor Labs, LLC
