In Altium, I have a non-plated through hole with a pad. The pad is assigned to net GND. I have a polygon pour defined as GND. When I pour the polygon, the pad has thermal connections to the pour, as expected, but when I run the DRC I get an "unrouted net" error associated with that pad.
I wanted the pad, connected to GND, I GOT the pad connected to GND, but Altium throws an error. Other than ignoring it, what's the way around this error?
