Author Topic: [Solved] identify multiple occurrences of device sheets in the generated pdf  (Read 1723 times)
Offline AucieleTopic starter
Hello everyone,
In many of my hierarchical project i use device sheets, board level annotation and "number schematic sheet". Once the project finished i use an outputjob to generate a PDF file.
1) device sheet share the same page number in the PDF in a way that i can end up with a 10 pages PDF but the highest page would be page 8 for example.
2) in the PDF i couldn't find any ways to identify a device sheet occurrence from one to another.
that lead to a really unpractical PDF schematic. Do you have some tips to share and solve this issue in any ways?
thanks.
« Last Edit: January 25, 2020, 09:18:19 am by Auciele »
Electronic engineer - Altium 10.1377.27009
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: identify multiple occurrences of device sheets in the generated pdf
« Reply #1 on: January 07, 2020, 08:27:22 pm »
Ah yes, this one took me a bit to figure out originally. Once you gain the understanding of how Altium works as a piece of software it makes much more sense.
To generate useful schematics from Hierarchical projects you need to do a few things differently.
First Compile your design!
Second annotate your compiled schematics: Tools > Annotation > Annotate Compiled Sheets... (you can change how this behaves by using the drop down arrow, I prefer to do a breadth first annotation, but dealers choice)
Third when you generate a schematic pdf from your output job file you need to have these settings:
Data Source = [Project Physical Documents]
*Double click on the schematic output*
Then set the following (ignore the settings in the top section you care about the physical name expansion):
You need to expand designators, and the sheet number parameter. I also expand ports to make those unique.
Best of luck to you!
~Bryan
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: Auciele
« Reply #2 on: January 08, 2020, 09:09:16 am »
Nice!   :-+
that will likely do the job but i was wondering, with your setup: ports gets a specific name that include the designator of the device sheet they belong to.
additionnaly is there a way to have a dynamic string in the device sheet that would depend on the device sheet designator to ease the identification?
thanks
Offline Pseudobyte
« Reply #3 on: January 10, 2020, 05:18:50 am »
I am not sure about the string thing. I looked quickly through the altium docs for a compiled parameter that would do what you want but didn't see anything.
« Reply #4 on: January 25, 2020, 09:17:21 am »
As a side note, when you publish a PDF, the index/bookmark title have a suffix with the device sheet designator. (but it only works for the  pdf reader. If you print the schematic, you'll lose this data).
i'll mark this subject as resolved.
