Author Topic: Is Circuit Maker different to Altium at all?  (Read 7545 times)
Offline FaringdonTopic starter
« on: July 01, 2023, 01:44:04 pm »
Hi
Or is it just a cut down copy of it?
I understand its free.?
If i want to find out how to use it, would i use standard Altium tutorial videos.?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline jc101
Re: Is Circuit Maker different to Altium at all?
« Reply #1 on: July 01, 2023, 01:49:36 pm »
Suspect it's very different, like Circuit Studio is.  You do know this requires an internet connection to work, plus the following may be important to you...
Users are allowed to have 5 private projects, the so-called sandbox mode for practicing. By default, all schematics and PCBs are uploaded to the server and can be viewed by other users as soon as they are committed through the internal svn engine. While this renders CircuitMaker undesirable for closed source projects, it encourages collaboration in the community.
The following users thanked this post: Faringdon
Offline matrixofdynamism
« Reply #2 on: October 29, 2023, 05:50:12 pm »
Please also look into KiCAD. It might be better (free) option than circuitmaker. I had assumed that circuit maker would be similar to Altium itself but its not.
Offline Jackster
    • PCBA.UK
« Reply #3 on: October 29, 2023, 08:46:31 pm »
CM and Altium are quite far apart but you can jump from one to another without much of a learning curve.
If you are new to ECAD, it is a great bit of software.
The recent 2.0 update has made it even closer to Altium but without all the bells and whistles.
A lot of people will suggest KiCAD over it but it really depends on what your needs are.
CM is so much more user-friendly than KiCAD full stop.
Offline voltsandjolts
« Reply #4 on: November 04, 2023, 09:13:12 am »
Please may i open this for all Altium problems? (save creating new post each time).
