Author Topic: Rooms  (Read 1566 times)
Offline Spark-DoctorTopic starter
Rooms
« on: June 14, 2020, 11:03:50 am »
Hi All
I am currently using a trial of AD20 and getting along quite well. I use Circuit Studio at the moment so it has been fairly easy to migrate over but i am having a problem with the Rooms.
I have completed all the schematics and move them over to the PCB. All of the rooms are created and labelled correctly. I grab the first room, move it into the PCB and move the components around. I then go and grab the second room and it will only move the room leaving all the components behind. I have deleted everything and re-loaded the rooms but it still happens.
I have found that after up-loading, whatever room i move first will move ok but whatever room i move next will only move the room itself, not the components.
Is this a BUG or am i doing something wrong????
Many Thanks
Ian
Online T3sl4co1l
    • Seven Transistor Labs
Re: Rooms
« Reply #1 on: June 14, 2020, 11:47:03 am »
Why do you have multiple rooms for the same components..?
Don't know that I've ever had a situation quite like that before; normally when I have components mis-named or mis-linked and tied to multiple rooms, it's a logical-or operation, i.e., the components will move with any room they are linked with; not an exclusive or first-come operation.  Seems to further suggest incorrect configuration in any case.
Rooms aren't too useful outside of hierarchical designs; you can disable them under Project/Options (C, O), Classes, Generate Rooms, untick for applicable files.
Seven Transistor Labs, LLC
Re: Rooms
« Reply #2 on: June 14, 2020, 12:30:25 pm »
I don't have multiple rooms for the same component. I have the power rails on 1 schematic, ADC on another, Arduino on another and so on.
When the rooms come across to the board, all the correct components are in the right room and i can pick any room at random, move it onto the board and arrange the components, but when i grab the next room, only the room moves, all of the components stay outside of the board.
Ian
Online T3sl4co1l
Re: Rooms
« Reply #3 on: June 14, 2020, 01:13:20 pm »
Ahh. So the components are unplaced, off board, and after touching any one room, they all stop working?  Or that initial one keeps working, none others?
Rooms are design rules; you can check their definitions there (D, R).  Maybe they're not set to move things, or maybe it's getting un-set somehow..?
Also, anything missing in Project/Component Links (C, K)?
Re: Rooms
« Reply #4 on: June 17, 2020, 07:32:53 pm »
Very strange outcome. I tried all your suggestions and problem persisted. Called Altium support and they got on Zoom and had a look. Turns out i was using the SamacSys Component search engine and still had the search box running in the background. When he closed it down, everything worked perfectly  :-//
Thank you for your help.
On a side not, very much like the software and have bought it.
The following users thanked this post: T3sl4co1l
