Author Topic: Moving from CM to Altium  (Read 2353 times)
Offline hitech95Topic starter
  • Computer technician playing with electronics...
    • Kytech
« on: May 30, 2019, 12:07:29 pm »
For my hobby projects I've used CM since it's release due to the fact that it's free... (And i was moving away from Eag ... ehm Autodesk  :palm:)
Feature wise it was not bad, even if sometimes it have proper designed software locks to slow down the development)
Anyway, I have decided to try out the full Altium (for my new more complicated project) so I have asked a trial.
I'm still having some problems in finding all the options and the keymap is partially different. My main problem so far is that i don't know a better way to quickly move stuff around.
On CM you just needed to select the components (or symbols) and with the M key you was able to move them around and by pressing SPACE it was also rotating.
Now on Altium I have to press M ath than use the mous to select an option on the context menu. Is there a better solution?
I don't have the access to the vault (beeing a demo) and it don't have lots of footprint, so I seached for a library project.
I'm using JLCPCB/LCSC a lot I I know that they have a Library for their SMT assembly line.
I downloaded it, all the footprints are present but for the resistors.schlib file (Once the project is compiled and imported) the symbol is not present and I cannot place it.
I then tried to see if was a corrupted file, but opening directly the resistor.schlib file the symbol was present. I than created a new .schlib file and I copied the component into that.
Also this new component had an empty symbol.
What am I doing wrong?
The only solution that i've found so far is to create the symbol from scratch!
Another question that i have, on CM the layers had names like "Outline for M1". Is there a way to configure them?
If I use the "Use short name version" it shows back the M1, M2.
And so far I don't exactly know what match what.
Thanks,
hitech95
« Last Edit: May 30, 2019, 12:23:30 pm by hitech95 »
The important thing is to get involved, and don't give up.
Offline ajb
Re: Moving from CM to Altium
« Reply #1 on: May 30, 2019, 04:16:25 pm »
Note that in the context menu a letter in each of the options is underlined.  You can use those letters to navigate through the menus.  So for instance, hit M, then S to move selection.  To place a wire use P,W. This is especially powerful in the pcb editor which has a lot more menu options.
I'm not sure about the library issue, as I use a DBLib of my own creation, but are you trying to place from the SchLib?  I think you need to build it as an IntLib so that the schematic and footprint symbols are linked and then place from that, but I haven't messed with IntLibs in a while.
    • Kytech
« Reply #2 on: May 30, 2019, 05:50:54 pm »
Yes i've discovered a fiew shortcuts in the first minutes (also by using some YT videos) but the one to move the selection was missing. So it's M+S  good to know.
Yes, the library project is a IntLib that (once compiled) it's included by default.
I have both the pcblib and the schlib.
But as you can see if I open the schlib file directly i can place and I have the symbol.
If I use the Library panel on the right it shows all the components but for some reason the resistor don't have the symbol.
    • Kytech
« Reply #3 on: June 05, 2019, 12:01:58 pm »
Is there any way to automate library copy & paste of symbols and parameters?
Unfortunatly the only way to make this working is to create the chlib from scratch.
